はじめに
If your laptop experienced a power surge or short circuit, you may need to replace the motherboard using this guide. This replacement only requires the screen portion of the laptop, so remove the keyboard before beginning.
必要な工具と部品
Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
Lift screen off of plastic cover to expose the internal components.
Remove the copper shield by removing the four Phillips screws that hold the shield in place.
Use a size 0 Phillips head screwdriver to remove the 4mm screw which secures the Wifi Card in place.
Make sure to carefully remove Wifi card from the motherboard to prevent damage.
To reassemble your device, simply follow these instructions in reverse order.
