メインコンテンツにスキップ
Toshiba Satellite CL15t-B1204X Power Connector Replacement
必要な工具と部品
  1. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 2、 1の画像 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 3、 1の画像 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 4、 1の画像 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 5、 1の画像 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 6、 1の画像 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 手順 7、 3の画像 1 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 手順 7、 3の画像 2 Toshiba Satellite CL15t-B1204X Power Connector Replacement, Power Connector: 手順 7、 3の画像 3
    • Disconnect the charging connector from the motherboard using the blue iFixIt opening tool by sliding it away from the connector.
  8. Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 8、 3の画像 1 Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 8、 3の画像 2 Toshiba Satellite CL15t-B1204X Power Connector Replacement: 手順 8、 3の画像 3
    • Pry the power connector upwards from the side of the laptop using the opening tool, then remove the part from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Matthew Hook
メンバー登録日: 03/25/19
439 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019人のメンバー
IUPUI-HOVDE-F19S1G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 332
