メインコンテンツにスキップ
Toshiba Satellite CL15t-B1204X Network Card Replacement
必要な工具と部品
  1. Toshiba Satellite CL15t-B1204X Network Card Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 2、 1の画像 1
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 3、 1の画像 1
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 4、 1の画像 1
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 5、 1の画像 1
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 6、 1の画像 1
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: 手順 7、 2の画像 1 Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: 手順 7、 2の画像 2
    • Peel off the black antenna stuck to the card.
  8. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 8、 2の画像 1 Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 8、 2の画像 2
    • Carefully use the PH1 screw head to unscrew the one 3mm screw on the network card found near the hinge at the top.
  9. Toshiba Satellite CL15t-B1204X Network Card Replacement: 手順 9、 1の画像 1
    • Remove the network card.
終わりに
作成者
2人の作成者と共同で作成されました。
Royce Alexander Porter
メンバー登録日: 09/10/18
661 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S2-G3, Menagarishvili Fall 2018 Appalachian State University, Team S2-G3, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G3
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 6
今までの合計 222
