はじめに
Use this guide to upgrade RAM or to replace defective RAM in your Toshiba Satellite C875-S7304.
RAM is an important hardware component that allows data to be read or written in the same time regardless of the location of said data inside the memory. Faulty RAM can result in blue screens of death (BSODs), error messages, diminished performance, untimely reboots, or freezes.
Review the troubleshooting page before using this guide. Some issues may be resolved through something as simple as a software update.
If you want to enhance your computer’s performance, you may want to upgrade your RAM. This device supports RAM in capacities ranging from 4 GB to 16 GB. Each RAM stick must be DDR3 1600 MHz and be between 4 GB and 8GB.
Disconnect the laptop from any external power source and power off your laptop completely before beginning RAM replacement.
Tools
必要な工具と部品
Power off and unplug the charger from your device.
Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
The two eject switches are located on the right and left side of the battery compartment.
Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
Repeat the steps above on the left side of the hard drive/RAM panel.
Pull the cover towards you and up from the device to remove it.
2 の人々がこのガイドを完成させました。
