メインコンテンツにスキップ
Toshiba Satellite C875-S7304 Motherboard Replacement
必要な工具と部品
  1. Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 2、 2の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 2、 2の画像 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 3、 1の画像 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 4、 1の画像 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 5、 1の画像 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to display the keyboard.
  7. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 7、 2の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 7、 2の画像 2
    • Using the iFixit opening tool, carefully remove the black plastic bar below the keyboard.
  8. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 8、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 8、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 8、 3の画像 3
    • Pry the keyboard up and apart from the device.
    • Disconnect the ribbon cable under the keyboard.
  9. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 9、 1の画像 1
    • Use a Phillips #1 screwdriver to remove all eight of the screws under the keyboard.
  10. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 10、 2の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 10、 2の画像 2
    • Close the device and carefully flip it back over.
  11. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 11、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 11、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 11、 3の画像 3
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel and remove panel.
    • Slide the hard drive laterally first and then lift the hard drive up using the clear tab.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  12. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 12、 1の画像 1
    • Use a Phillips #1 to remove all 15 of the screws holding the bottom panel intact.
  13. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 13、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 13、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 13、 3の画像 3
    • Grab the optical drive on either side.
    • Pull the drive out of the device laterally.
  14. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 14、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 14、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 14、 3の画像 3
    • Gently pry open the entire bottom panel, pulling upward to remove the panel from the device.
  15. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 15、 3の画像 1 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 15、 3の画像 2 Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 15、 3の画像 3
    • Remove all wiring from the motherboard and pry it from the device slowly making sure that no ribbons or wires are connected.
  16. Toshiba Satellite C875-S7304 Motherboard Replacement: 手順 16、 1の画像 1
    • Gently remove the motherboard from inside the device. You are now ready to replace the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Emma King
メンバー登録日: 09/04/19
334 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S2-G5, Bedsole Fall 2019 University of Alabama, Team S2-G5, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S2G5
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 37
今までの合計 1,665
