メインコンテンツにスキップ
Toshiba Satellite C875-S7304 Hard Drive Replacement
必要な工具と部品
  1. Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C875-S7304 Hard Drive Replacement, Battery: 手順 1、 3の画像 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 2、 2の画像 1 Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 2、 2の画像 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 3、 1の画像 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 4、 1の画像 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 5、 1の画像 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 7、 3の画像 1 Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 7、 3の画像 2 Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 7、 3の画像 3
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 8、 3の画像 1 Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 8、 3の画像 2 Toshiba Satellite C875-S7304 Hard Drive Replacement: 手順 8、 3の画像 3
    • Pull the hard drive laterally to disconnect it from the laptop.
    • Use the clear tab to lift the hard drive out of the laptop.
    • When reassembling, make sure the hard drive lies flat in the laptop before reconnecting it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Taimoor Arshad
メンバー登録日: 09/04/19
381 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S2-G5, Bedsole Fall 2019 University of Alabama, Team S2-G5, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S2G5
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 20
今までの合計 1,022
