メインコンテンツにスキップ
Toshiba Satellite C875-S7304 Display Replacement
必要な工具と部品
  1. Toshiba Satellite C875-S7304 Display Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C875-S7304 Display Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C875-S7304 Display Replacement, Battery: 手順 1、 3の画像 3
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Display Replacement: 手順 2、 2の画像 1 Toshiba Satellite C875-S7304 Display Replacement: 手順 2、 2の画像 2
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Display Replacement: 手順 3、 1の画像 1
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Display Replacement: 手順 4、 1の画像 1
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Display Replacement: 手順 5、 1の画像 1
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 Display Replacement, Display: 手順 6、 2の画像 1 Toshiba Satellite C875-S7304 Display Replacement, Display: 手順 6、 2の画像 2
    • Carefully flip the device back over so that the 'TOSHIBA' logo faces away from you.
    • Open the laptop to show the display.
  7. Toshiba Satellite C875-S7304 Display Replacement: 手順 7、 1の画像 1
    • Use the spudger to remove the screw covers and then remove the screws using the Phillips #1.
  8. Toshiba Satellite C875-S7304 Display Replacement: 手順 8、 2の画像 1 Toshiba Satellite C875-S7304 Display Replacement: 手順 8、 2の画像 2
    • Using the iFixit opening tool, carefully remove the plastic frame from the display.
  9. Toshiba Satellite C875-S7304 Display Replacement: 手順 9、 1の画像 1
    • Remove two screws from each hinge on either side using the Phillips #1 screwdriver.
    • There are two screws on each hinge.
  10. Toshiba Satellite C875-S7304 Display Replacement: 手順 10、 1の画像 1
    • Rotate the laptop so that the side is facing you.
    • Remove the three screws using the Phillips #1 screwdriver on each side of the display.
    • There will be six total screws removed in this step (three on each side face).
  11. Toshiba Satellite C875-S7304 Display Replacement: 手順 11、 1の画像 1
    • Turn the display over to expose the wiring on the other side.
  12. Toshiba Satellite C875-S7304 Display Replacement: 手順 12、 2の画像 1 Toshiba Satellite C875-S7304 Display Replacement: 手順 12、 2の画像 2
    • Gently loosen the sliding bracket and remove the cable.
    • If you want to use the same webcam, disconnect it from the back of the display.
  13. Toshiba Satellite C875-S7304 Display Replacement: 手順 13、 1の画像 1
    • With the display now fully disconnected, carefully remove it from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nathan Gareri
メンバー登録日: 09/04/19
211 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team S2-G5, Bedsole Fall 2019 University of Alabama, Team S2-G5, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S2G5
4 メンバー
15のガイドは作成済み
コメント 1 件
I love this site....best
Hafiz - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 24
今までの合計 821
