はじめに
This guide will show you how to replace your laptops fan. This process requires only a small Phillips head screwdriver and your hands.
必要な工具と部品
Lay your laptop upside down on a flat surface.
Power off your laptop and unplug the charger.
Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
ある他の人がこのガイドを完成しました。
