はじめに
You might need to replace your CMOS (Complementary Metal Oxide Semiconductor) battery if your Toshiba laptop is losing its time and date settings or if you are receiving a CMOS error message. You will also need to remove your CMOS before replacing other elements, such as the motherboard.
必要な工具と部品
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
2 の人々がこのガイドを完成させました。
