メインコンテンツにスキップ
Toshiba Satellite C675-S7106 Wireless Card Replacement
必要な工具と部品
  1. Toshiba Satellite C675-S7106 Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 2、 2の画像 1 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 2、 2の画像 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Wireless Card Replacement, Keyboard: 手順 3、 1の画像 1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 4、 3の画像 1 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 4、 3の画像 2 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 4、 3の画像 3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 5、 3の画像 1 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 5、 3の画像 2 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 5、 3の画像 3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 6、 3の画像 1 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 6、 3の画像 2 Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 6、 3の画像 3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
  7. Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 1 Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 2
    • Underneath the keyboard, gently disconnect the black and white wires on the right of the wireless adapter using a thin plastic spudger.
    • Be sure to properly re-connect the two wires during assembly, perhaps using the back end of the spudger to ensure that the connection is made.
  8. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 8、 1の画像 1
    • Unscrew the one 3mm screw in the top-left corner of the wireless adapter using a PH0 screwdriver.
  9. Toshiba Satellite C675-S7106 Wireless Card Replacement: 手順 9、 1の画像 1
    • Lift the card up and to the right to remove it from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Dinis Valcorba
メンバー登録日: 03/26/19
292 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019人のメンバー
UMASSD-SIMCOCK-S19S1G2
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 269
