はじめに
Replacing and re-seating RAM is a common fix and upgrade done to laptops. This laptop model makes it easy - all you’ll need is a PH0-head screwdriver and a pry tool.
必要な工具と部品
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
