はじめに
CMOS / BIOS Battery replacement for Toshiba Satellite C660 with video tutorial:
ビデオの概要
  1. Disconnect the charger and the battery.
    • Disconnect the charger and the battery.
  2. Remov the narrow plastic lid and unscrew 4x Phillips screw.
    • Remov the narrow plastic lid and unscrew 4x Phillips screw.
    • Remove the keyboard.
    • This is the internal CMOS / BIOS battery. Use small screwdriver to remove it.
まとめ
9 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
161,543 ポイント
304のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
279 メンバー
769のガイドは作成済み
what battery do i need
allan mccauley - 返信
This is a CR2032 battery
Hyperion - 返信
The receptacle that the battery goes into is loose and not making contact on the (+) terminal. This is a shoddy design. You can test it by pressing the receptacle down and powering the laptop. Works fine. You cannot solder the terminal for fear of upsetting the motherboard. Any solutions.
Until I find one, I continue to press F1, go to Control Panel and set the time and date every time I power on the laptop.
Hari Razdan - 返信
same battery CR2032 for Toshiba sattelite L775 G10 ?
thx
gagalot Eric - 返信
統計データを表示:
過去 24時間: 6
過去 7 日: 107
過去 30 日: 443
今までの合計 18,151
