はじめに
Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
  1. Turn the laptop over and place upside down on a flat surface. Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
      • There are two tabs for each of the two RAM modules.
      • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  4. Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
まとめ
3 の人々がこのガイドを完成させました。
Shelby Kunz
メンバー登録日: 2013年04月19日
45 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G20
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 2,534
