メインコンテンツにスキップ
Toshiba Satellite C655-S5212 LCD Screen Replacement
必要な工具と部品
  1. Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 2 Toshiba Satellite C655-S5212 LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 3
    • First remove the stickers covers the screws in the 4 corners of LCD case. Stickers are very thin and using utility knife is easiest way to remove without damaging them. After removing stickers unscrew top 2 screws then proceed to Step 2 before trying to remove bottom 2 screws.
  2. Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 2、 3の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 2、 3の画像 2 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 2、 3の画像 3
    • Turn laptop around to back, and undo the 2 latches in back in order to remove bottom 2 screws of LCD screen. Use your utility knife to slide into crack and push down to unlatch.
  3. Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 3、 2の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 3、 2の画像 2
    • Once screws are removed, remove cover bezel from LCD very gently without breaking it, you should hear clicking noise when removing.
  4. Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 4、 2の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove 2 screws at bottom of LCD frame and also the 2 screws at top of LCD frame (not pictured). This will allow you to lay the back cover away from frame to access side easier and remove the 3 screws on each side to detach LCD screen. Do not pull LCD once unscrewed, lay down face down on keyboard for last step.
  5. Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 5、 3の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 5、 3の画像 2 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 5、 3の画像 3
    • Before trying to remove video cable from back of LCD. First gently remove cable from adhesive holding it down to board. Then remove tape from top of cable holding connector in place. Be very gentle at these points.
  6. Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 6、 3の画像 1 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 6、 3の画像 2 Toshiba Satellite C655-S5212 LCD Screen Replacement: 手順 6、 3の画像 3
    • Now gently pull tab to pull cable from slot, be careful not to pull too hard and damage pins when removing. Once removed remove board and install new one.
終わりに
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Barrington Edman
メンバー登録日: 07/10/12
1,145 ポイント
3のガイドは作成済み
2 件のコメント
Aoa sir....where to buy a new lcd screen for toshiba core i3??? Plz tell me
kingkhan201189 - 返信
I usually get mine from Amazon or Ebay. On the back of LCD there is a sticker with the model number
Barrington Edman - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 7,853
