メインコンテンツにスキップ
はじめに
In the case you need to replace the battery of your Toshiba Satellite C55D-C5106, this guide will aid you to replace it.
  1. Make sure the laptop is powered off Turn the laptop upside down.
    • Make sure the laptop is powered off
    • Turn the laptop upside down.
  2. Remove screws on the back of the device securing the battery with a Phillips #1 screwdriver.
    • Remove screws on the back of the device securing the battery with a Phillips #1 screwdriver.
  3. Gently remove the battery in outwards motion. The battery should come out with ease.
    • Gently remove the battery in outwards motion. The battery should come out with ease.
終わりに
Laura Tamayo
メンバー登録日: 2019年02月14日
678 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019人のメンバー
USFT-LEAHY-S19S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 156
