メインコンテンツにスキップ
Toshiba Satellite C55D-B5310 Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite C55D-B5310 Keyboard Replacement, Keyboard: 手順 1、 2の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement, Keyboard: 手順 1、 2の画像 2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 2、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 2、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 2、 3の画像 3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
  3. Toshiba Satellite C55D-B5310 Keyboard Replacement, CD/DVD Drive: 手順 19、 1の画像 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  4. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 20、 2の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 20、 2の画像 2
    • Slide the CD/DVD Drive out of the laptop.
  5. Toshiba Satellite C55D-B5310 Keyboard Replacement, Fan: 手順 21、 1の画像 1
    • Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  6. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 22、 2の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 22、 2の画像 2
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  7. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 23、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 23、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 23、 3の画像 3
    • Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
    • Lift the fan cable connector from the fan.
  8. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 24、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 24、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 24、 3の画像 3
    • Remove the fan from the plug by releasing the clamps located on each side of the socket.
    • Slide the connector out of the socket.
    • Lift the computer fan from the motherboard.
  9. Toshiba Satellite C55D-B5310 Keyboard Replacement, Keyboard: 手順 25、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement, Keyboard: 手順 25、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement, Keyboard: 手順 25、 3の画像 3
    • Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
  10. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 26、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 26、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 26、 3の画像 3
    • The white touchpad ribbon must be disconnected from the motherboard connection socket.
    • Release the two clamps holding the ribbon in place.
    • Slide the ribbon from the motherboard connection socket.
  11. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 27、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 27、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 27、 3の画像 3
    • Remove the white ribbon connecting the USB ports to the motherboard.
    • Release the two holding clamps.
    • Slide the ribbon out of the motherboard holding socket.
  12. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 28、 1の画像 1
    • Remove the 7 mm Phillips screw holding the USB Driver to the motherboard using the PH1 bit and Magnetic Driver.
  13. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 29、 2の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 29、 2の画像 2
    • Remove the blue ribbon connecting the hard drive hardware to the motherboard by first lifting the yellow protective tape.
    • Slide the blue ribbon from its connection socket.
  14. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 30、 3の画像 1 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 30、 3の画像 2 Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 30、 3の画像 3
    • Carefully separate the securing tape from the ribbon attaching the keyboard to the motherboard.
    • At this point the keyboard will be free from the motherboard.
  15. Toshiba Satellite C55D-B5310 Keyboard Replacement: 手順 31、 1の画像 1
    • Slide the keyboard ribbon through its holding slot, completely releasing it from the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Christopher White
メンバー登録日: 01/18/18
345 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 769
