はじめに
In this guide we will show you how to safely remove the screen of your Toshiba Satellite C55D device. If the screen of your device is cracked, it will be best to remove the screen for replacement. Removing the screen is a delicate process because of how fragile the material is. We aim to provide you with a step by step tutorial on how to easily remove the screen.
必要な工具と部品
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Use a spudger to pry the top corner of the casing by performing an upward motion.
Continue to remove the casing using your hands.
3 の人々がこのガイドを完成させました。
