メインコンテンツにスキップ
Toshiba Satellite C55D-B5206 RAM Replacement
必要な工具と部品
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: 手順 1、 1の画像 1
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 2、 1の画像 1
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 3、 1の画像 1
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 4、 1の画像 1
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 5、 1の画像 1
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 6、 1の画像 1
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: 手順 7、 1の画像 1
    • Gently remove the RAM and insert replacement.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
David Amodei
メンバー登録日: 11/30/17
160 ポイント
1ガイドが承認済み
チーム
Coast Union High School, Team S1-G5, Hartzell Fall 2017 Coast Union High School, Team S1-G5, Hartzell Fall 2017人のメンバー
CUHS-HARTZELL-F17S1G5
3 メンバー
3のガイドは作成済み
コメント 1 件
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 541
