はじめに
Hard disks may crash after long periods of use. In the event your hard drive crashes, or you simply desire to upgrade to a solid state drive. Replacing the hard drive is moderately easy and requires a few simple steps.
必要な工具と部品
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
7 の人々がこのガイドを完成させました。
2 件のコメント
Thanks.. Really helped out..
