メインコンテンツにスキップ
Toshiba Satellite C55D-B5206 CD Drive Replacement
必要な工具と部品
  1. Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: 手順 1、 2の画像 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 2、 2の画像 1 Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 2、 2の画像 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 CD Drive Replacement, Back Casing: 手順 3、 1の画像 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 4、 1の画像 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 5、 3の画像 1 Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 5、 3の画像 2 Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 5、 3の画像 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 CD Drive Replacement, CD Drive: 手順 6、 1の画像 1
    • The 7 mm Philips#1 screw has been removed in the back casing removal.
    • Place thumb on the edge of the CD-ROM drive.
    • Gently slide the CD-ROM drive towards your palm.
  7. Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 7、 2の画像 1 Toshiba Satellite C55D-B5206 CD Drive Replacement: 手順 7、 2の画像 2
    • Lift away the CD-ROM drive.
    • You should feel the CD-ROM drive detach from the connector port.
    • The drive should slide out and lift away with little resistance. There is no need to slide the drive roughly.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Tayyaba
メンバー登録日: 09/24/15
523 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015人のメンバー
CSUF-BRUCE-F15S2G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 11
今までの合計 665
