はじめに
This guide will show you how to easily remove a CD drive to clean it or replace it with a new one. Do not be intimidated by the size of the CD-ROM drive, it is fairly easy to remove.
必要な工具と部品
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
The 7 mm Philips#1 screw has been removed in the back casing removal.
Place thumb on the edge of the CD-ROM drive.
Gently slide the CD-ROM drive towards your palm.
5 の人々がこのガイドを完成させました。
