メインコンテンツにスキップ
Toshiba Satellite C55D-A5201 Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 2、 1の画像 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 3、 2の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 3、 2の画像 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: 手順 4、 2の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: 手順 4、 2の画像 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 5、 1の画像 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 6、 1の画像 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 7、 3の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 7、 3の画像 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 7、 3の画像 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 8、 2の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 8、 2の画像 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 9、 3の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 9、 3の画像 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 10、 2の画像 1 Toshiba Satellite C55D-A5201 Keyboard Replacement: 手順 10、 2の画像 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
終わりに
13 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kari Byrd
メンバー登録日: 03/24/15
614 ポイント
1ガイドが承認済み
チーム
Baylor, Team 6-5, Shaver Spring 2015 Baylor, Team 6-5, Shaver Spring 2015人のメンバー
BU-SHAVER-S15S6G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 5,823
