メインコンテンツにスキップ
Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement
必要な工具と部品
  1. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Battery: 手順 1、 1の画像 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 手順 2、 1の画像 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 手順 3、 1の画像 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Hard Drive: 手順 4、 1の画像 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 手順 5、 1の画像 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 手順 6、 3の画像 1 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 手順 6、 3の画像 2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: 手順 6、 3の画像 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: 手順 7、 2の画像 1 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: 手順 7、 2の画像 2
    • Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
  8. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 手順 8、 2の画像 1 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: 手順 8、 2の画像 2
    • The card will pop up; gently pull the card out of the port.
    • Unplug the wireless antenna cables attached to the card.
    • Remember how the cables were connected to assure you do not cross the Bluetooth and wireless connections by accident.
終わりに
作成者
3人の作成者と共同で作成されました。
Ryan Smith
メンバー登録日: 10/25/19
187 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 40
今までの合計 927
