メインコンテンツにスキップ
Toshiba Satellite C55-C5268 LAN Card Replacement
必要な工具と部品
  1. Toshiba Satellite C55-C5268 LAN Card Replacement, Battery: 手順 1、 1の画像 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 2、 2の画像 1 Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 2、 2の画像 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 LAN Card Replacement, Back Panel: 手順 3、 1の画像 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 4、 2の画像 1 Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 4、 2の画像 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 5、 2の画像 1 Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 5、 2の画像 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 手順 6、 2の画像 1 Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 手順 6、 2の画像 2
    • Gently remove the ribbon cable from the clip its held in. Peel back the tape holding it in and pull the cable straight out. It is not necessary to unclip the holder.
    • The correct ribbon has a blue ends labeled with LAN.
  7. Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 7、 1の画像 1
    • Remove the two 5.0 mm screws, using a Phillips #1 screwdriver, once the cable is out of the way.
  8. Toshiba Satellite C55-C5268 LAN Card Replacement: 手順 8、 1の画像 1
    • Lift the card out of the laptop to replace it.
終わりに
作成者
4人の作成者と共同で作成されました。
Ben Rounseville
メンバー登録日: 10/21/16
471 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G1
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 1,381
