メインコンテンツにスキップ
Toshiba Satellite C55-C5268 Disk Drive Replacement
必要な工具と部品
  1. Toshiba Satellite C55-C5268 Disk Drive Replacement, Battery: 手順 1、 1の画像 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 2、 2の画像 1 Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 2、 2の画像 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Disk Drive Replacement, Back Panel: 手順 3、 1の画像 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 4、 2の画像 1 Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 4、 2の画像 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 5、 2の画像 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Disk Drive Replacement, Disk Drive: 手順 6、 1の画像 1
    • Unscrew one 3.0 mm screw from the disk drive using a #1 Phillips screwdriver.
  7. Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 7、 2の画像 1 Toshiba Satellite C55-C5268 Disk Drive Replacement: 手順 7、 2の画像 2
    • Grab the disk drive with one hand and the laptop with another, then gently pull the disk drive straight toward yourself.
    • Pull it in a straight line horizontally until it is completely removed.
    • This does not require much force, so be gentle.
終わりに
作成者
4人の作成者と共同で作成されました。
Ben Rounseville
メンバー登録日: 10/21/16
471 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G1
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 394
