メインコンテンツにスキップ
はじめに
These are the steps for removing the screen bezel from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and a systematic way to keep all the unscrewed screws as there are going to be a large number of them with different dimensions. Since we will be working in close proximity with the monitor screen, you should be careful not to scratch it.
  1. Flip laptop upside down so you can see the screws. Flip laptop upside down so you can see the screws.
    • Flip laptop upside down so you can see the screws.
  2. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing. Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Pull the battery from the back of the laptop for removal from the laptop.
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver. Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off. Expect to hear popping as you pull the back panel off.
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Disconnect the fan wire from the motherboard.
    • Disconnect the fan wire from the motherboard.
  6. PCラップトップ用バッテリー
    An easy fix for a big power boost.
    ショップを見る
    PCラップトップ用バッテリー
    ショップを見る
  7. Remove the three  3 mm screws with a Phillips #00 screwdriver. Remove the 5 mm screw with a Phillips  #0 screwdriver. Remove the 5 mm screw with a Phillips  #0 screwdriver.
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  8. You can now lift the fan out of the laptop.
    • You can now lift the fan out of the laptop.
  9. After the fan has been removed, lift the hinge so as to get  access to the parts below it. Remove the the black colored cable that is now exposed. Remove the the black colored cable that is now exposed.
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  10. Remove the 7 mm Phillips  #0 screw on the other hinge. Remove the 3.1 mm Phillips  #0 screw on the the same hinge. Lift the hinge up and towards you.
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  11. Pull out the wide cable to reveal the components underneath. Pull out the wide cable to reveal the components underneath.
    • Pull out the wide cable to reveal the components underneath.
  12. Remove the 3.1 mm Phillips #0 screw  holding the chip in place. Pull out the chip.
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  13. Hold the cable that is to be removed. Use an iFixit opening tool to push down on the white protrusion of cable connector. Now you can pull out the cable.
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  14. Pivot and lift up the monitor and separate it from the base of the laptop. Pivot and lift up the monitor and separate it from the base of the laptop. Pivot and lift up the monitor and separate it from the base of the laptop.
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  15. Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges. Use the metal spudger to separate the rest of the bezel. Be careful not to scratch the screen with the metal spudger.
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
まとめ
ある他の人がこのガイドを完成しました。
David Browning
メンバー登録日: 2019年03月25日
301 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G3, Henning Spring 2019 IUPUI, Team S1-G3, Henning Spring 2019人のメンバー
IUPUI-HENNING-S19S1G3
4 メンバー
3のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 85
