はじめに
These are the steps for removing the screen bezel from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and a systematic way to keep all the unscrewed screws as there are going to be a large number of them with different dimensions. Since we will be working in close proximity with the monitor screen, you should be careful not to scratch it.
必要な工具と部品
After the fan has been removed, lift the hinge so as to get access to the parts below it.
Remove the the black colored cable that is now exposed.
ある他の人がこのガイドを完成しました。
2 件のコメント
Sir how will I find screen strip of toshiba c55-b1326
Sir how can I find screen strip of toshiba c55-b1326
