メインコンテンツにスキップ
Toshiba Satellite C55-A5300 Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 2、 3の画像 1 Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 2、 3の画像 2 Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 2、 3の画像 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Keyboard Replacement, Hard Drive: 手順 3、 1の画像 1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 6、 1の画像 1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Keyboard Replacement, Fan: 手順 7、 1の画像 1
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 8、 1の画像 1
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 9、 2の画像 1 Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 9、 2の画像 2
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 10、 2の画像 1 Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 10、 2の画像 2
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
  11. Toshiba Satellite C55-A5300 Keyboard Replacement, CD Drive: 手順 11、 1の画像 1
    • Remove the screw to the top right of the hard drive using the PH1 screwdriver.
  12. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 12、 1の画像 1
    • Use the plastic opening tool to wedge between the CD Drive and the laptop casing and gently pull it out.
  13. Toshiba Satellite C55-A5300 Keyboard Replacement, Keyboard: 手順 13、 1の画像 1
    • The screws holding the keyboard in place have already been removed along with the back panel, so just push the keyboard out of the laptop by pushing your fingers through the holes under the fan and CD drive.
  14. Toshiba Satellite C55-A5300 Keyboard Replacement: 手順 14、 1の画像 1
    • Once the keyboard is hanging out of the laptop, separate it from the device by pulling out the tab connecting the keyboard to the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
David Burleson
メンバー登録日: 09/09/18
391 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S2-G1, Menagarishvili Fall 2018 Appalachian State University, Team S2-G1, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G1
3 メンバー
15のガイドは作成済み
コメント 1 件
My A5302 has 1 screw near the ID sticker that secures the keyboard. Then just use the pry tool to work around the edge to pop it out and unplug. Always remove battery first
Guy - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 652
