メインコンテンツにスキップ
Toshiba Satellite C55-A5300 Fan Replacement
必要な工具と部品
  1. Toshiba Satellite C55-A5300 Fan Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C55-A5300 Fan Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C55-A5300 Fan Replacement, Battery: 手順 1、 3の画像 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Fan Replacement: 手順 2、 3の画像 1 Toshiba Satellite C55-A5300 Fan Replacement: 手順 2、 3の画像 2 Toshiba Satellite C55-A5300 Fan Replacement: 手順 2、 3の画像 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Fan Replacement, Hard Drive: 手順 3、 1の画像 1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Fan Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Fan Replacement: 手順 5、 1の画像 1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Fan Replacement: 手順 6、 1の画像 1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Fan Replacement, Fan: 手順 7、 1の画像 1
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Fan Replacement: 手順 8、 1の画像 1
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Fan Replacement: 手順 9、 2の画像 1 Toshiba Satellite C55-A5300 Fan Replacement: 手順 9、 2の画像 2
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Fan Replacement: 手順 10、 2の画像 1 Toshiba Satellite C55-A5300 Fan Replacement: 手順 10、 2の画像 2
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
終わりに
作成者
3人の作成者と共同で作成されました。
David Burleson
メンバー登録日: 09/09/18
391 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S2-G1, Menagarishvili Fall 2018 Appalachian State University, Team S2-G1, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G1
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 381
