メインコンテンツにスキップ
Toshiba Satellite C55-A5300 CD Drive Replacement
必要な工具と部品
  1. Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite C55-A5300 CD Drive Replacement, Battery: 手順 1、 3の画像 3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 2、 3の画像 1 Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 2、 3の画像 2 Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 2、 3の画像 3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 CD Drive Replacement, Hard Drive: 手順 3、 1の画像 1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 5、 1の画像 1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 6、 1の画像 1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 CD Drive Replacement, CD Drive: 手順 7、 1の画像 1
    • Remove the screw to the top right of the hard drive using the PH1 screwdriver.
  8. Toshiba Satellite C55-A5300 CD Drive Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to wedge between the CD Drive and the laptop casing and gently pull it out.
終わりに
作成者
2人の作成者と共同で作成されました。
David Burleson
メンバー登録日: 09/09/18
391 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S2-G1, Menagarishvili Fall 2018 Appalachian State University, Team S2-G1, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G1
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 248
