はじめに
This guide will show you how to remove or replace the hard drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
必要な工具と部品
2 の人々がこのガイドを完成させました。
コメント 1 件
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
