はじめに
If you ever find yourself wishing you had more capacity in your laptop's hard drive, replacing your old one with a larger one might be the option for you. This guide will show you how to replace the old hard drive in a Toshiba Satellite with a new one.
必要な工具と部品
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Place the laptop with the bottom facing up.
Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
もう少しです!
終わりに
