メインコンテンツにスキップ
Toshiba Satellite C55-A5100 Charging Port Jack Replacement
必要な工具と部品
  1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Battery: 手順 1、 1の画像 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 2、 1の画像 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 手順 3、 3の画像 1 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 手順 3、 3の画像 2 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: 手順 3、 3の画像 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 4、 1の画像 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 5、 1の画像 1
    • Remove the disc drive from the device.
  6. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 手順 6、 3の画像 1 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 手順 6、 3の画像 2 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: 手順 6、 3の画像 3
    • Place the laptop with the bottom facing up.
  7. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 7、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  8. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 8、 2の画像 1 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 8、 2の画像 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  9. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Charging Port Jack: 手順 9、 1の画像 1
    • Unscrew all 15 screws that attach the back cover to the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  10. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 10、 3の画像 1 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 10、 3の画像 2 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: 手順 10、 3の画像 3
    • Locate the charging jack. Then carefully pull straight up.
    • Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Rei Rutkowski
メンバー登録日: 11/26/18
184 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S8-G8, Wilson Fall 2018 IUPUI, Team S8-G8, Wilson Fall 2018人のメンバー
IUPUI-WILSON-F18S8G8
4 メンバー
6のガイドは作成済み
コメント 1 件
Hi. Correction on Step 9. Aside from the 15 black screws, I had to unscrew one silver screw. It sits right under the HDD.
Everything else was perfectly described.
Isidro B. - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 18
今までの合計 1,429
