メインコンテンツにスキップ
はじめに
This guide will show you how to successfully replace your Toshiba Satellite laptop's battery. It is a very simple process that does not involve the use of tools. Located on the back of the laptop, you can detach it without removing anything else.
  1. Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Lift the battery upward with your fingers out of the battery compartment.
    • Lift the battery upward with your fingers out of the battery compartment.
まとめ
ある他の人がこのガイドを完成しました。
Robert Redding
メンバー登録日: 2018年01月29日
135 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team S3-G10, Bedsole Spring 2018 University of Alabama, Team S3-G10, Bedsole Spring 2018人のメンバー
UA-BEDSOLE-S18S3G10
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 177
