メインコンテンツにスキップ
Toshiba Satellite A85-S107 15" Wireless Card Replacement
必要な工具と部品
  1. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Back Panel: 手順 1、 1の画像 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 2、 1の画像 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 3、 1の画像 1
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 4、 2の画像 1 Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 4、 2の画像 2
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 5、 1の画像 1
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 6、 1の画像 1
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
  7. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 1 Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: 手順 7、 2の画像 2
    • Carefully pull the white auxiliary wire out of its socket on the wireless card.
    • Now repeat this step with the black auxiliary wire.
    • Be careful when removing the wires, as the wireless card and the wires are delicate.
  8. Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 8、 2の画像 1 Toshiba Satellite A85-S107 15" Wireless Card Replacement: 手順 8、 2の画像 2
    • Push the two black tabs, located on the sides of the card, away from the card.
    • The right side of the wireless card should now pop out of its holder.
    • Pull the wireless card out by lifting it from the dock and sliding it towards the right.
終わりに
作成者
13人の作成者と共同で作成されました。
Travis
メンバー登録日: 04/13/13
31 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G38
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 755
