メインコンテンツにスキップ
Toshiba Satellite A85-S107 15" Hard Drive Replacement
必要な工具と部品
  1. Toshiba Satellite A85-S107 15" Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 2、 1の画像 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 3、 2の画像 1 Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 3、 2の画像 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Flip the computer around so the battery is facing away from you.
  5. Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 5、 2の画像 2
    • Locate 5mm Philips #0 screw on hard drive cover.
    • Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
  6. Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 6、 2の画像 1 Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 6、 2の画像 2
    • Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate.
    • If the hard drive panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  7. Toshiba Satellite A85-S107 15" Hard Drive Replacement: 手順 7、 1の画像 1
    • Use plastic opening tool to lift hard drive out of case.
    • Lift the left side of the hard drive and slide it out towards the left.
    • We do not have all the required parts for this guide.
終わりに
作成者
11人の作成者と共同で作成されました。
Travis
メンバー登録日: 04/13/13
31 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-38, Amido Spring 2013 Cal Poly, Team 10-38, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G38
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,015
