ツール
パーツ
パーツは指定されていません。
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
Using the Phillips Screwdriver, remove the two 8.6 mm screws from the front edge of the motherboard.
5 の人々がこのガイドを完成させました。
2 件のコメント
Thanks Garrett...
Your time and effort in putting this guide together is much appreciated (and helpful!)
Rick
