メインコンテンツにスキップ
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
必要な工具と部品
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 2、 2の画像 1 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 2、 2の画像 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 3、 3の画像 1 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 3、 3の画像 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 3、 3の画像 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 5、 2の画像 2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 6、 2の画像 1 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: 手順 6、 2の画像 2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
終わりに
作成者
3人の作成者と共同で作成されました。
Cassie Pickett
メンバー登録日: 03/20/17
201 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team S8-G1, Bennett Spring 2017 Texas Tech, Team S8-G1, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G1
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 497
