メインコンテンツにスキップ
Toshiba Satellite A65-S126 Optical Drive Replacement
必要な工具と部品
  1. Toshiba Satellite A65-S126 Optical Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 2、 1の画像 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Optical Drive Replacement, Upper Assembly: 手順 3、 1の画像 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 4、 1の画像 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 5、 2の画像 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 6、 1の画像 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 7、 1の画像 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Optical Drive Replacement, Optical Drive: 手順 9、 1の画像 1
    • Orient the bottom assembly as displayed.
  10. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 10、 2の画像 1 Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 10、 2の画像 2
    • Remove the two 3 mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Optical Drive Replacement: 手順 11、 1の画像 1
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
終わりに
作成者
5人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
89,934 ポイント
89のガイドは作成済み
コメント 1 件
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
J Howard Markley - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 977
