はじめに
This guide provides step by step instructions of how to replace a faulty optical drive.
  1. Flip the laptop over so the bottom is facing up.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Gently lift the battery out of the computer.
    • Gently lift the battery out of the computer.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
    • Remove the WIFI module cover. It will pull right off.
    • Unplug the white and black wires from the WiFi module.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
    • Use the plastic opening tool to pry the two halves apart.
    • Orient the bottom assembly as displayed.
    • Remove the two 3 mm Phillips #00 screws.
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
まとめ
Geoff Wacker
メンバー登録日: 2013年09月30日
73,677 ポイント
84のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 625
