メインコンテンツにスキップ
Toshiba Satellite A505-6005 Charging Port Replacement
必要な工具と部品
  1. Toshiba Satellite A505-6005 Charging Port Replacement, Remove The battery: 手順 1、 3の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove The battery: 手順 1、 3の画像 2 Toshiba Satellite A505-6005 Charging Port Replacement, Remove The battery: 手順 1、 3の画像 3
    • The battery can be removed by sliding the mechanism on the left to the right. Once this is done slide the mechanism further to the right while pulling up on the battery.
    • Use the Phillips #0 screwdriver to remove the two screws under the battery.
  2. Toshiba Satellite A505-6005 Charging Port Replacement, Remove all screws from the bottom: 手順 2、 3の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove all screws from the bottom: 手順 2、 3の画像 2 Toshiba Satellite A505-6005 Charging Port Replacement, Remove all screws from the bottom: 手順 2、 3の画像 3
    • Remove nine screws with a Phillips #0 screwdriver and then remove the cover of the hard drive/RAM.
    • You can see the covers in picture one.
  3. Toshiba Satellite A505-6005 Charging Port Replacement, Remove hard drive/ ram sticks: 手順 3、 2の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove hard drive/ ram sticks: 手順 3、 2の画像 2
    • Once the screw for the hard drive is removed, gently pull on the ribbon to completely unplug the hard drive.
    • Use a spudger to gently push the sides of the clip holding both RAM sticks into place. After that, simply pull the RAM sticks out.
  4. Toshiba Satellite A505-6005 Charging Port Replacement, Remove disc drive: 手順 4、 3の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove disc drive: 手順 4、 3の画像 2 Toshiba Satellite A505-6005 Charging Port Replacement, Remove disc drive: 手順 4、 3の画像 3
    • Use a plastic opening tool to pry the disc drive open and remove it. This will be easy, as you have already removed the screws holding the disc drive in place.
    • Do not forget to remove the three screws under the disc drive. I found the best way to do this is to use a long screwdriver with a small magnetic Phillips tip.
  5. Toshiba Satellite A505-6005 Charging Port Replacement, Remove trip  piece on top of keyboard: 手順 5、 2の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove trip  piece on top of keyboard: 手順 5、 2の画像 2
    • Gently pry up with a plastic opening tool on the bottom of the trim in the little slots that are cut out.
    • Remove the four screws under the small piece.
  6. Toshiba Satellite A505-6005 Charging Port Replacement, Remove Keyboard: 手順 6、 2の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove Keyboard: 手順 6、 2の画像 2
    • Gently pull up on the keyboard after the four screws have been removed.
    • There will be a ribbon anchoring the keyboard in place. Use a plastic opening tool to push against the small black clip holding it in place, then carefully remove the ribbon.
  7. Toshiba Satellite A505-6005 Charging Port Replacement, Remove visible screws: 手順 7、 3の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove visible screws: 手順 7、 3の画像 2 Toshiba Satellite A505-6005 Charging Port Replacement, Remove visible screws: 手順 7、 3の画像 3
    • Near the top of the keyboard there will be two power sources to unplug. Gently unplug both of them.
    • Near the bottom of the picture you'll see an area where a ribbon is plugged in. Remove the ribbon cable.
  8. Toshiba Satellite A505-6005 Charging Port Replacement, Remove Cover: 手順 8、 3の画像 1 Toshiba Satellite A505-6005 Charging Port Replacement, Remove Cover: 手順 8、 3の画像 2 Toshiba Satellite A505-6005 Charging Port Replacement, Remove Cover: 手順 8、 3の画像 3
    • Now the charging port will be exposed. Simply unplug and remove the old one, and plug in and properly place the new charging port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Austin Wattles
メンバー登録日: 03/29/20
187 ポイント
1ガイドが承認済み
チーム
Purdue University Northwest, Team S6-G1, Hingst Spring 2020 Purdue University Northwest, Team S6-G1, Hingst Spring 2020人のメンバー
PNW-HINGST-S20S6G1
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 28
今までの合計 572
