メインコンテンツにスキップ
Toshiba Satellite A505 series Battery Replacement
  1. Toshiba Satellite A505 series Battery Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite A505 series Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn the system over and locate the locking switches near the battery.
    • This switch is not spring-loaded. Slide it away from the battery to unlock.
    • This switch IS spring-loaded and will have to be held to release the battery. It slides in the opposite direction of the first switch.
    • The example here shows an after-market high-capacity battery. The procedure is the same, regardless.
終わりに
Follow this procedure in reverse to install the (new) battery. Note that the second switch will engage automatically upon install. The first switch will not and must be locked manually once the battery is in place.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jerry F Nerviano
メンバー登録日: 11/18/10
2,125 ポイント
1ガイドが承認済み
チーム
Jerry's Computer Service Jerry's Computer Service人のメンバー
Business
1 メンバー
3のガイドは作成済み
4 件のコメント
I have a Toshiba statellite click W35Dt-A3300 window 8.1
How do I take and put new battery in ?
eddiecabral32 - 返信
Have you seen the Toshiba Satellite Click guides? This should be the battery guide you need: Toshiba Satellite Click Tablet Battery Replacement.
Sam Goldheart -
I have a Toshiba A356-S69253 and the battery after a long charge reads 7 - 13 % Charge. On rare occasion I see 97% but within a minute or two the computer shuts down. When I restart the charge is down to 3%. I am having uncontrolled shut down and other problem and suspect a battery problem
The Battery is built in. Can I change the battery? How much is a battery? Can someone else change the battery? How much $? The laptop is pretty old, is it worth trying to fix?
buschwa@aol.com 7/2/2017
buschwa - 返信
Hvordan tager jeg batteri ud af en Toshiba Satellite L50D-A-10D
Birthe Kirkgaard - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 16
今までの合計 4,269
