Turn device onto its screen side to access the bottom of hinge portion of the screen and push bottom piece of frame along device hinge until it loosens.
Hold the screen with one hand and gently remove the display cable from the back side of the screen.
The display cable is typically glued or taped to the back of the screen. Take care to carefully lift the tape and slowly pull cable.
To avoid damaging screen ribbon cable, use caution and be gentle. Do not yank or remove with force. Avoid bending the ribbon cable which can cause the wires inside it to snap and break.
