必要な工具と部品
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Locate 2 metal pinchers on either side of the 1st RAM stick.
Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
もう少しです!
終わりに
