必要な工具と部品
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Locate hard drive cover opposite the battery on the lower left corner of the device.
Loosen 2 Phillips 4.2 mm size captive screws from cover.
Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
ある他の人がこのガイドを完成しました。
