はじめに
This guide will teach you how to get your laptop apart and replace it with a new screen. To put your laptop back together just follow the steps in reverse. Remember to make sure to keep track of your screws!
必要な工具と部品
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Place laptop right side up on a flat and clean surface. Open the laptop.
Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
この手順で使用する道具:Tweezers$4.99
Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
Pull out the cable and completely remove the keyboard.
Begin by carefully removing the rubber bumper pads located at each corner of the plastic screen casing.
Using a Phillips screwdriver you may unscrew and remove the screws located directly under the the rubber bumper pads. Remember to keep track of the removed screws!
2 の人々がこのガイドを完成させました。
