はじめに
When your computer heats up and runs loudly, it may need some new fans to keep the runnin' machine cool.This guide will teach you how to get to the fans inside your laptop and replace them. Just make sure to keep track of your screws!
必要な工具と部品
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Place laptop right side up on a flat and clean surface. Open the laptop.
Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
this was very difficult. snaps would not release desite using ifixit pry tool. they released then would pop vback on trying to release the remaing fasteners
Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
Pull out the cable and completely remove the keyboard.
Turn computer over so that the battery compartment is facing up and is at the top.
Locate and unscrew one captive Phillips #1 screw located at the center.
7 の人々がこのガイドを完成させました。
コメント 1 件
I have a Toshiba Satellite P50-BOOG Serial No. YEO15554S. It has sided on me after 18 months and the repair man says it needs a new mother
board. It seems that Toshiba do not recognise the numbers above. I am wondering if this is a copy of Toshiba although I bought it from reputable retailer. Its a lot of money to throw away. Do you know of anyone who deals with Toshiba mother boards in NZ?
