メインコンテンツにスキップ
Toshiba Satellite A215 S4697 Fan Replacement
必要な工具と部品
  1. Toshiba Satellite A215 S4697 Fan Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement, Battery: 手順 1、 3の画像 3
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Toshiba Satellite A215 S4697 Fan Replacement: 手順 2、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 2、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 2、 3の画像 3
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Toshiba Satellite A215 S4697 Fan Replacement, Keyboard: 手順 3、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement, Keyboard: 手順 3、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement, Keyboard: 手順 3、 3の画像 3
    • Place laptop right side up on a flat and clean surface. Open the laptop.
    • Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
    • Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
  4. Toshiba Satellite A215 S4697 Fan Replacement: 手順 4、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 4、 2の画像 2
    • Locate the two 2.3mm Phillips #1 screws at the top of the keyboard that attaches the keyboard to the frame behind it.
    • Remove screws.
  5. Toshiba Satellite A215 S4697 Fan Replacement: 手順 5、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 5、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 5、 3の画像 3
    • Find the latch above the F8 key that overlaps the keyboard.
    • Use a plastic opening tool to press the key board's tab downward, until the key board is released.
  6. Toshiba Satellite A215 S4697 Fan Replacement: 手順 6、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 6、 2の画像 2
    • Pull the keyboard out by shifting it forward towards the screen and pulling up.
    • CAUTION: Do not pull it out all the way yet. It is still attached to the laptop by a cable.
  7. Toshiba Satellite A215 S4697 Fan Replacement: 手順 7、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 7、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 7、 3の画像 3
    • Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
    • Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
    • Pull out the cable and completely remove the keyboard.
  8. Toshiba Satellite A215 S4697 Fan Replacement, Optical Drive: 手順 8、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement, Optical Drive: 手順 8、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement, Optical Drive: 手順 8、 3の画像 3
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  9. Toshiba Satellite A215 S4697 Fan Replacement: 手順 9、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 9、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 9、 3の画像 3
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  10. Toshiba Satellite A215 S4697 Fan Replacement: 手順 10、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 10、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 10、 3の画像 3
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  11. Toshiba Satellite A215 S4697 Fan Replacement: 手順 11、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 11、 2の画像 2
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  12. Toshiba Satellite A215 S4697 Fan Replacement: 手順 12、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 12、 2の画像 2
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  13. Toshiba Satellite A215 S4697 Fan Replacement: 手順 13、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 13、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 13、 3の画像 3
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  14. Toshiba Satellite A215 S4697 Fan Replacement: 手順 14、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 14、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 14、 3の画像 3
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
  15. Toshiba Satellite A215 S4697 Fan Replacement, Fan: 手順 15、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement, Fan: 手順 15、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement, Fan: 手順 15、 3の画像 3
    • Close the lid and flip the laptop over so that the bottom side is facing you.
    • Remove nineteen 8mm Phillips #1 screws, labeled with "F8."
    • Locate and Remove two "f4" screws as well.
  16. Toshiba Satellite A215 S4697 Fan Replacement: 手順 16、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 16、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 16、 3の画像 3
    • Locate the RAM compartment.
    • Unscrew the two Phillips #1 screws and lift the lid up.
    • Note that these two screws do not detach from lid.
  17. Toshiba Satellite A215 S4697 Fan Replacement: 手順 17、 1の画像 1
    • Unscrew the two 8mm Phillips #1 screws inside the RAM compartment.
  18. Toshiba Satellite A215 S4697 Fan Replacement: 手順 18、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 18、 2の画像 2
    • Remove the three 3mm Phillips #1 screws inside the battery compartment.
  19. Toshiba Satellite A215 S4697 Fan Replacement: 手順 19、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 19、 2の画像 2
    • Turn computer over and open lid.
    • Make sure all the screws are cleared off the device before you flip the device over.
    • Remove the four 8mm Phillips #1 screws in the slot where the keyboard sat.
  20. Toshiba Satellite A215 S4697 Fan Replacement: 手順 20、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 20、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 20、 3の画像 3
    • Locate the speaker cables near the top right corner.
    • Use tweezers to carefully disconnect the cable.
  21. Toshiba Satellite A215 S4697 Fan Replacement: 手順 21、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 21、 2の画像 2
    • Locate the cable on the bottom left hand corner of keyboard slot.
    • Gently pull it out to the left.
  22. Toshiba Satellite A215 S4697 Fan Replacement: 手順 22、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 22、 2の画像 2
    • Locate the cable at the top of the frame.
    • Using tweezers, pull tabs on either side, toward the screen, and pull the cable out of socket.
  23. Toshiba Satellite A215 S4697 Fan Replacement: 手順 23、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 23、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 23、 3の画像 3
    • Locate another ribbon cable at the lower center of the keyboard slot.
    • Using tweezers, pull tabs out to the left, and pull cable out of socket.
  24. Toshiba Satellite A215 S4697 Fan Replacement: 手順 24、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 24、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 24、 3の画像 3
    • Using a plastic opening tool, insert into slit around laptop and separate the silver frame from black bottom.
    • The black lip on the front of the laptop is part of the top silver frame.
    • Lift frame away from laptop.
  25. Toshiba Satellite A215 S4697 Fan Replacement: 手順 25、 1の画像 1
    • Locate the fan in the top left hand corner of the inside of the laptop.
    • Remove the following screws from the fan encasement:
    • Two 12 mm Phillips #1 screws
    • Two 2.3 mm Phillips #1 screws.
  26. Toshiba Satellite A215 S4697 Fan Replacement: 手順 26、 3の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 26、 3の画像 2 Toshiba Satellite A215 S4697 Fan Replacement: 手順 26、 3の画像 3
    • Pull away gray flat cable from the fan so that it is no longer stuck to the fan's surface.
    • Disconnect cable by pulling the black end to the left so that it detaches from the white plastic piece.
  27. Toshiba Satellite A215 S4697 Fan Replacement: 手順 27、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 27、 2の画像 2
    • Using tweezers, disconnect power cable by gently pulling white end straight away from its socket.
  28. Toshiba Satellite A215 S4697 Fan Replacement: 手順 28、 2の画像 1 Toshiba Satellite A215 S4697 Fan Replacement: 手順 28、 2の画像 2
    • Lift fan up out of laptop.
    • Pull out any dust or use a pressurized air duster to clean the fan.
終わりに
7 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Grace Cowell
メンバー登録日: 04/15/13
273 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-12, Maness Spring 2013 Cal Poly, Team 4-12, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S4G12
4 メンバー
18のガイドは作成済み
コメント 1 件
I have a Toshiba Satellite P50-BOOG Serial No. YEO15554S. It has sided on me after 18 months and the repair man says it needs a new mother
board. It seems that Toshiba do not recognise the numbers above. I am wondering if this is a copy of Toshiba although I bought it from reputable retailer. Its a lot of money to throw away. Do you know of anyone who deals with Toshiba mother boards in NZ?
clarereid - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 13,619
