はじめに
If your laptop displays an error while reading a CD or DVD, does not play audio or video properly, or CD or DVD programs do not install or encounter errors after installation, then use this guide to remove and replace your DVD drive.
必要な工具と部品
Remove the 3mm screw using a Phillips #00 screwdriver located beneath the RAM module cover. This screw holds the DVD drive in place.
ある他の人がこのガイドを完成しました。
