メインコンテンツにスキップ
Toshiba Satellite A205-S4577 USB 3.0 ports Replacement
必要な工具と部品
  1. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Battery: 手順 1、 1の画像 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 2、 1の画像 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 手順 3、 3の画像 1 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 手順 3、 3の画像 2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: 手順 3、 3の画像 3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 4、 1の画像 1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 5、 1の画像 1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Front Cover: 手順 6、 1の画像 1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  7. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 7、 2の画像 1 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 7、 2の画像 2
    • Lift up on the front cover to remove it.
  8. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, USB 2.0 Ports: 手順 8、 1の画像 1
    • Locate the USB 2.0 cable on the bottom right corner of the laptop.
  9. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 9、 2の画像 1 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: 手順 9、 2の画像 2
    • Locate the white slot on the left side of the USB 2.0 wire.
    • Carefully detach the wire by pulling the cable to the right of the slot.
終わりに
作成者
7人の作成者と共同で作成されました。
Curtis
メンバー登録日: 04/18/13
103 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-6, Regan Spring 2013 Cal Poly, Team 17-6, Regan Spring 2013人のメンバー
CPSU-REGAN-S13S17G6
5 メンバー
33のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 1,749
